Author Balancing throttle bodies  (Read 2572 times)
  • Offline Foxy
    • SX Master  ‐    908
    • #10
    Offline Foxy
    • Bike: Black 2011 SX AB
    • City / Town: Leeds
    Re: Balancing throttle bodies
    Reply #10 on: 11 Feb 24, 07:35:04
    11 Feb 24, 07:35:04
  • Offline Foxy
    • SX Master  ‐    908
    • #11
    Offline Foxy
    Reply #11 on: 11 Feb 24, 07:43:51
    11 Feb 24, 07:43:51
    So basically, I was working from the Kawasaki service manual and the details for balancing were quite brief. Reading the Haynes manual introduced the concept of restricting the gauges and when I took the throttle bodies off and saw the difference in hole size for the gauge feeds I thought it's got to be that that was causing the issue. The later models have dedicated vacuum feeds for each body , so I'm guessing that anyone balancing those wouldn't have the same issue. The gauges I bought didn't come with instructions and there were no restrictors in the tubes, it was only by finding instructions for other gauges that I found I needed to cut each hose in half and insert the restrictor! Why they didn't come like this from the factory I'll never know. Never mind, we live and learn!
  • Online Timmy_Biker   gb
    • SX Master  ‐    686
    Online Timmy_Biker
    • Bike: 2016 Z1000SX Tourer
    • Country: gb
    Reply #12 on: 11 Feb 24, 07:57:06
    11 Feb 24, 07:57:06
    Ah! Well done Foxy, this is good info for any other Z owners willing to take on this maintenance work.
    Glad you got it sorted and it wasn't something larger like burned valve seat etc..
    I salute you for your perseverance !!
     :820:
  • Offline whyhaveone   england
    • SX God  ‐    2803
    Reply #13 on: 12 Feb 24, 09:32:28
    12 Feb 24, 09:32:28
    *Originally Posted by Timmy_Biker [+]
     :820:
    +1, well done.  :047: I realise that it has been a pain, but hopefully you now feel very satisfied!
  • Offline Foxy
    • SX Master  ‐    908
    • #14
    Offline Foxy
    Reply #14 on: 12 Feb 24, 12:29:38
    12 Feb 24, 12:29:38
    Thanks for the feedback Chaps, It was certainly a learning experience and I reckon I spent around 5 days in total  :005: but this was down to checking and rechecking after the spurious vacuum reading!
    Like most things in life, the more you do something, the better you get and I think I could probably now do the plugs, shims, oil service and throttle balance on this model within a day.
    One useful tip when changing the plugs was to make sure you put a universal joint directly attached to the plug socket and then add the extension to that (instead of putting the extension on the plug socket and the UJ on the extension) a small change but this made plug removal and fittings much more accessible   :028:
    Last Edit: 12 Feb 24, 12:34:03 by Foxy
    • SX God  ‐    2803
      #15
    Reply #15 on: Yesterday at 03:03:05 pm
    A bit late but........... :028:
