whyhaveone whyhaveone
Author Charging  (Read 5560 times)
  • Offline Muso   gb
    • SX Junior  ‐    7
    Offline Muso
    • Bike: Z1000sx 2011
    • Country: gb
    Charging
    on: 31 Oct 23, 06:10:34
    31 Oct 23, 06:10:34
    Hi everyone , I have a 2011 z1000st which I think has a charging problem , at idle the battery voltage is 13.4v
    But when I increase rpm to 4000 ,the voltage drops to around 13.1,so I'm thinking the regulator rectifier has packed up ?
    I need to to do some tests on the the regulator,but I don't know where it is located ,I'm waiting for a manual coming ,but would like to at least gain access to it asap
  • Offline ZPETE   england
    • SX Master  ‐    294
    Offline ZPETE
    Re: Charging
    Reply #1 on: 01 Nov 23, 10:01:51
    01 Nov 23, 10:01:51
    On my 2015, the reg/rec is behind the left hand fairing panel.
    I would imagine yours is the same.
  • Offline HeavyRain   gb
    • SX Pro  ‐    109
    Offline HeavyRain
    • City / Town: Swindon
    • Country: gb
    Re: Charging
    Reply #2 on: 01 Nov 23, 04:09:56
    01 Nov 23, 04:09:56
    Make sure you've got a known, good battery before fannying about with diagnosing the charging system.
  • Offline Muso   gb
    • SX Junior  ‐    7
    • #3
    Offline Muso
    • Country: gb
    Re: Charging
    Reply #3 on: 01 Nov 23, 07:10:03
    01 Nov 23, 07:10:03
    I have just put a Shido Lithium Battery on and tested again here are the results
    Idling 13.48
    4000rpm 13.7
    Main beam at idle 12.9
    4000rpm with main beam 13.7
    Manual says.. regulated voltage output 14.2 to 15.2
    I'm getting nowhere near those voltages
  • Offline Muso   gb
    • SX Junior  ‐    7
    • #4
    Offline Muso
    • Country: gb
    Re: Charging
    Reply #4 on: 06 Nov 23, 10:22:05
    06 Nov 23, 10:22:05
    well i'll close this one off by saying i done some tests and stator is fine and in spec , rectifier is fine and in spec , but the regulator isn't regulating properly
    ordered a replaced from Fowlers £145 .....ouch !!!
