Experience-Matters Experience-Matters
Author Topic: LED Headlight Bulbs  (Read 97979 times)
#420
Offline Robbus
  • Bike: '15 Z1000SX
Re: LED Headlight Bulbs
Reply #420 on: 29 Sep 19, 11:44:51
Big thanks to Maccmike for super quick supply of the spacers. Bulbs are in and look to be working great. First proper test tomorrow night.
Has anyone managed/bothered to tighten the grub screw on the heat sinks?
Cheers,
Rob
#421
Online maccmike
Reply #421 on: 29 Sep 19, 01:45:14
*Originally Posted by Robbus [+]
Cheers,
Rob
Thanks Rob. Found it too difficult to get at the grub screw so didn't bother to tighten it. My thoughts are the heat sink will not come loose if tightened enough against the rubber boot, and after 3 years there are no signs of it coming off.
#422
Offline Robbus
  • Bike: '15 Z1000SX
Reply #422 on: 29 Sep 19, 09:01:10
*Originally Posted by maccmike [+]
My thoughts too, and it's easy enough to stick a hand in to check them now and again. Thanks Mike!
#423
Offline Runich
Reply #423 on: 01 Oct 19, 11:16:09
Many thanks to Maccmike for supplying his spacers.  I fitted the LED head and side lamps yesterday (the same models as previous recommendations) and they work really well.  One gotcha is that I found the grub screws on the heat sink are delicate and quite difficult to remove with the supplied allen key.  I had to send one set back since the grub screw was rounded off and I couldn't remove the heat sink.
#424
Offline Shorty
Reply #424 on: 02 Oct 19, 10:38:22
Morning
Im just about to have a go with the led install and just wanted to check that i have the spacer correct. Thanks all
#425
Offline Runich
Reply #425 on: 02 Oct 19, 10:45:05
Pretty much, although the spacer should be pushed up so that it is flush and lined up with the flange on the LED lamp.
#426
Offline Shorty
Reply #426 on: 02 Oct 19, 10:58:34
AH cheers, so no gap then between the original and Mikes spacers ?
#427
Offline Runich
Reply #427 on: 02 Oct 19, 11:04:03
Yes, that's right.  Then install into lamp housing, secure with clip, install the rubber cover and replace the heatsink.
#428
Offline Shorty
Reply #428 on: 02 Oct 19, 05:03:20
Well job done and thanks to every one for the advice. Took fairing panels off to make life easier. All done now including the side lights.
Cheers all
#429
Offline gipsymagpie
  • Bike: Z1000SX 2016
Reply #429 on: 18 Nov 19, 07:08:23
Now had LED in for a while with no issues, although my led don't seem to have the external fan you all seem to have.
Anyway, decided to add my Denali spots too so now have veritable light fest.
In reality all lights are a good colour match (LED in headlight, LED sidelight bulbs, Barkbuster LED handguards, 2x Bikevis bullets plus Denali D2 spots (in 1000% more with high beam, 50% with dipped).   Night ride test to come.
Also just in case there are any questions, yes the indicators do still stand out when lit.
Used a mounting plate on same bolt as r&g bungs
Last Edit: 18 Nov 19, 07:10:13 by gipsymagpie
