Author Topic: What did you do to your Z1000SX today?  (Read 787324 times)
BrianBRD, SteveMat, Scotty001 and 12 Guests are viewing this topic.
#4230
Offline Essex Blue
  • Bike: Ninja
Re: What did you do to your Z1000SX today?
Reply #4230 on: 06 Sep 20, 08:07:21
Looks better than I though they would.
Feed back would be good as I’m about to charge my heated gloves but prefer to have heated grips with thinner gloves
#4231
Reply #4231 on: 07 Sep 20, 12:05:38
I had the heated grips and Barkbusters on my 2016SX. As per one of my posts in the current heated grips topic for me it's the ideal solution.
They do work well with (or without) heated grips, they keep the majority of the wind chill off as well as rain. With heated grips I was wearing my summer waterproof gloves for the majority of my winter rides without getting cold hands. Note: I tend not to ride at anything below about 6C.
#4232
Offline MattS
Reply #4232 on: 09 Oct 20, 05:21:22
Today i undid a previous mod, the EBC Vee rotors had to go!
They made a pulsing vibration through the bike which felt like old ABS cutting in but faster, very different to warped discs, which is why the OEM discs were changed in the first place. On removal I found another issue, the ABS sensor was rubbing its pickup ring just enough to take the paint off.
I got the micrometer out and the EBC discs are 5.75mm thick at the hub, the replacement Brembo Gold Series are 5.00mm. So they should cure both problems :062:
£285 the pair delivered from Italy
https://www.ebay.co.uk/itm/Discs-Brembo-Kawasaki-Z-1000-Sx-Abs-2012-Brake-Floating-Pair-Front-Motorcycle/362944238224?hash=item5481299290:g:uWoAAOSw~yJebJNB
I know they're for a 2012, but they fit my 2017 perfectly.
Last Edit: 09 Oct 20, 05:23:41 by MattS
#4233
Reply #4233 on: 10 Oct 20, 12:12:42
I also had issues with EBC discs, the XC version. They were significantly thicker and heavier than than the OEM discs. I'd not buy them again.
#4234
Reply #4234 on: 17 Oct 20, 08:31:49
Just got a clicking noise from the starter relay and was the same even after a overnight charge. Ordered and fitted a new battery. 9 years out of the original so can't complain - original replacement was only £35 including delivery so also decided to invest in a oxford oximiser 3x, so expecting at least 20 years out of this one  :008:
#4235
Offline wirral_biker
  • Bike: Z1000SX Z900RS
  • City / Town: Wirral
Reply #4235 on: 23 Oct 20, 06:10:11
*Originally Posted by Foxy [+]
They don't make them like they used to!    :001:
Now, wen I wus a lad............
#4236
Offline Hicko93
  • Bike: Z1000SX PerfTour
  • City / Town: Cheshire
Reply #4236 on: Yesterday at 08:29:16 AM
Only just had my SX but set to fitting Oxford heated grips, 12v power socket, pyramid front fender extender.
Also received my Shad top box bracket but no need to fit that yet, all fairly straightforward, scariest thing was removing the left side fairing, make's me nervous.
Cheers
#4237
Online Scotty001
Reply #4237 on: Today at 09:06:26 AM
Flushed and bled all brake lines and replaced pads all round with EBC HH, I bought an Oxford one way valve bleed kit for £10 and to be honest best £10 spent for bleeding flushing brakes.
Tube over bleed nipple, slide the clip over to keep it in place, other end of the tube into empty coke bottle with a hole in the cap for the tube, crack off the bleed nipple and just pump the brake lever till all air out / fluid is  flushed through. (making sure you keep the reservoir topped up) once flushed / bled tighten bleed nipple, remove tube and a few pulls on brake lever to check you have pressure.
Saved a lot of time and trouble and much cheaper than the mityvic bleed system I have miss placed.
