Author Topic: Changing the brake and clutch lever positions.  (Read 760 times)
Offline AndyR
  • Bike: Ninja1000SX
  • City / Town: Preston
  • Country: U.K.
Hi all,
I find the brake and clutch levers are set a little too high as standard so I’m thinking of moving them down a little.
Presumably this is just a case of backing off the clamps setting the position and re-tightening. Do they need to be torqued and if so what to?
Cheers,
Andy
Offline kwacky
  • Bike: Africa Twin AS.
  • City / Town: Birmingham
Re: Changing the brake and clutch lever positions.
Reply #1 on: 22 Oct 21, 01:45:28
I've done the same.
I didn't bother checking torque settings. I only used a small Allen key and it was hand tight with a tiny drop of blue locktite
Reply #2 on: 24 Oct 21, 10:15:44
i've also done this. From the 2016 workshop manual:
•Tighten the upper clamp bolt first, and then the lower clamp bolt. There will be a gap at the lower part of the clamp after tightening
Torque - Front Master Cylinder Clamp Bolts: 11 N·m, 1.1kgf·m, 97 in·lb
Torque - Clutch lever clamp bolts: 7.8 N.m, 0.80kgf.m, 69 in·lb
Offline AndyR
  • Bike: Ninja1000SX
  • Country: U.K.
Reply #3 on: 25 Oct 21, 08:37:59
Thanks guys,
Much appreciated!
Andy
