I am sure this must have been covered before, but I cannot find the answer.
I want to fit a Denali PowerHub to tidy up some accessory wiring.
I had intended to fit the Powerhub under the pillion seat where the tool kit is located. However there is not sufficient room to allow the pillion seat to 'sit' properly. If I put it under the rider's seat towards the rear of the battery it becomes slightly inaccessible. Can anyone suggest a more suitable place?
The location of a switched power source is proving problematic, for me at least. Is there a suitable wire of sufficient free length that I can tap into. I am somewhat nervous about cutting a wire only to find the two ends can't be easily joined!
Any help and advice would be very much appreciated.
