Author Topic: Heated grips  (Read 1802 times)
Online burty
Re: Heated grips
Reply #10 on: 23 Oct 20, 10:48:14
*Originally Posted by keithzx [+]
As Oxford recommends they work better direct    Personally I have never found them warm enough same as the Kawasaki stock grips ( might be my hands ??).  The best grips I have used is the more reasonably priced r& g ones toasty !!!!
I suspect that Oxford say that as it removes the part of the installation that is outside of their control.
Offline BobBell
  • City / Town: Bracknell
Re: Heated grips
Reply #11 on: 24 Oct 20, 04:28:07
But they have designed them that way with the turn off feature
Re: Heated grips
Reply #12 on: 24 Oct 20, 08:17:40
They are designed to shut off when they detect the current drop. You also get a healthier current supply first from the battery through the Oxford cables
Online burty
Re: Heated grips
Reply #13 on: 24 Oct 20, 08:29:57
So long as the accessory wiring and the connections in the supply and earth are is in good condition it really shouldn't give you a significant voltage drop.
As Oxford have designed these to be wired direct to the battery then that is obviously an acceptable installation.  My personal preference would always be to only have items permanently powered if they have to be.
#14
Re: Heated grips
Reply #14 on: 24 Oct 20, 09:24:35
They are still only live when turned on   The control unit switches itself off if you don’t
#15
Offline Grez
Re: Heated grips
Reply #15 on: 24 Oct 20, 05:48:51
Thanks forc advice according to instruction it say straight onto battery
#16
Offline Grez
Re: Heated grips
Reply #16 on: 25 Oct 20, 05:15:51
All done connection to battery. Took side fairing off ran cable behind ....nice and warm  :001:
#17
Offline BobBell
Re: Heated grips
Reply #17 on: 25 Oct 20, 06:19:08
You won't cope with that heat for long, they really do get hot, especially if you wear summer gloves
#18
Re: Heated grips
Reply #18 on: 25 Oct 20, 08:45:00
i wish mine would get hot !!!!
