Author Topic: Where to install a Scott oiler  (Read 641 times)
0 Members and 3 Guests are viewing this topic.
Offline Peterbennetive
  • Bike: SX, 10R & ZXR750
  • City / Town: Benfleet, Essex
on: 06 Jul 20, 02:37:31
Hi all. I have a Scott oiler fitted by my dealer under the riders seat which is a bit of a pain to adjust and to keep an eye on to top up. I’m thinking of moving it and looking for better ideas. Where have you installed yours?
Last Edit: 06 Jul 20, 02:39:34 by Peterbennetive
Offline ian
  • Country: great britain
Re: Where to install a Scott oiler
Reply #1 on: 12 Jul 20, 10:54:08
depending which model you have
if you don't have panniers on the pannier stay on the LHS
i'll post an image later to illustrate
Reply #2 on: 12 Jul 20, 11:38:27
*Originally Posted by ian [+]
I have a 2016 model with panniers.
Offline Harley
  • Bike: Z1000
Reply #3 on: 14 Jul 20, 12:45:17
I drilled a6mm hole through the rear left peg  hand bracket and set it on the inside of the bracket, done this on both ninjas I’ve owned . If u have the facility get a pice of 6mm bore aluminium tubing and cut off 6mm long at45 degrees to provide an angled washer. This works well especially if u make and fix a v shaped dripper, with brass tubing, this oils the chain better
Reply #4 on: 14 Jul 20, 09:06:27
Sounds interesting. Have you got a picture?
Offline BubbaGump
  • Bike: 2018 sx
  • City / Town: Auckland
  • Country: New Zealand
Reply #5 on: 14 Jul 20, 11:27:47
Hi mate, I've got mine cable tied to the inside of the left hand foot peg hanger but ive got the e system so the filler is on the side.
:027:
Last Edit: 14 Jul 20, 11:31:25 by BubbaGump
Offline maccmike
Reply #6 on: 14 Jul 20, 11:39:52
Made a small bracket to fit as shown, nicely out of the way but easily accessible. Later on fitted a lube tube under the seat so filling only necessary about 3500 miles.
Reply #7 on: 14 Jul 20, 11:53:00
That's where l was thinking of putting it but l thought it would catch on the swing arm
Offline ian
Reply #8 on: 17 Jul 20, 02:21:53
may not work with panniers
Reply #9 on: 17 Jul 20, 02:30:03
Yes. That is where my panniers go so no good for me unfortunately.
