Author Topic: Puddle of fluid  (Read 603 times)
Offline Squiffy
Puddle of fluid
on: 01 Jul 20, 11:44:34
hi guys n gals not sure if I'm in the right section but here goes, got to work this morning, short distance 3.5miles. And found a puddle under the bike around the cat, there is what looks like a breather pipe that had been dripping, the liquid was clear cool not oily or greasy. Question is what is the breather for ? Located (as looking side on) behind the rear brake lever and why would it leak so much fluid?
Offline keithzx
Re: Puddle of fluid
Reply #1 on: 01 Jul 20, 12:46:54
it is probably just water / condensation ,
Online burty
Re: Puddle of fluid
Reply #2 on: 01 Jul 20, 01:34:36
I wasn't aware of there being any breathers that exit on the brake pedal side of the bike.  There is a tank overflow, and tank cap drain  that exit in front of the front sproket.  There is also the expansion tank breather that also exits somewhere.
If this is clean water then it's either condensation or rainwater that your bike has stored for you.  Otherwise the only liquid in the bike that would exit out of a pipe is coolant and normally that is obviously not plain water.
Offline keithzx
Re: Puddle of fluid
Reply #3 on: 01 Jul 20, 02:09:19
I occasionally got a drip between the cat and the exhaust were the clamp is  On my last 2017 Sx.  just an idea
Re: Puddle of fluid
Reply #4 on: 01 Jul 20, 04:50:15
Isn't it the drain pipe for the neck of the fuel tank. Probably had water in there
Online burty
Re: Puddle of fluid
Reply #5 on: 01 Jul 20, 09:21:14
*Originally Posted by KD [+]
That exits on the left.  Definitely not behind the brake lever.
Offline Sojourner
  • Bike: '14 Z1000SX
  • Country: Thailand
Re: Puddle of fluid
Reply #6 on: 04 Jul 20, 05:45:05
The fuel tank breather hose, other than SX's for California and countries that require carbon filled catch tanks, exits directly over the pivot point of the swing arm. That may be your source.
Offline Squiffy
Re: Puddle of fluid
Reply #7 on: 12 Jul 20, 12:04:31
Thanks for all the suggestions, I decided to actually take a proper look, I appears when my bike was "serviced" they overfilled the expansion tank so when my bike got hot (short journey to work) the water was forced through the overflow hence the pool of fluid
