burty
Author Topic: 2020 Ninja Cree light wiring  (Read 444 times)
  • Bike: 2020 Ninja 1000S
on: 19 May 20, 04:32:17
I bought these for my 2020 Ninja, note they do 1W and 3W versions, these are the 3W. Previously I have had bullet lights for my 2013 and 2016 models.
https://www.alchemyparts.co.uk/pair-of-white-projector-3w-cree-led-daytime-running-lights-drl-for-motorcycles-motorbikes-scooters-quads-trikes-cars/
There may be some repetition here re dash removal for the 2017-2019 models?
To start:
1. Remove the windshield - 4 allen bolts
2. Remove the front upper cowling each side of the tank. 1 pop rivet, 1 allen bolts, 3 lugs. Slide forwards
3. Remove the Meter cowling TOP fixings - 2 pop rivets, 2 allen bolts
4. Slide down the top nose cone piece.
5. Remove the meter cowling back fixings - 2 allen bolts per side. (1 pop rivet and 1 allen bolt per side already removed in 2 above)
5. You can now see the meter cowling instrument cluster connector. Slide off the boot, depress the catch and remove the connector. You can now see the last bolt retaining the meter cowling
6. Meter housing back
More to follow:
Re: 2020 Ninja Cree light wiring
Reply #1 on: 19 May 20, 04:48:02
All this to get at the accessory connector behind the headlamp! It's tucked way down and taped up to the main loom.
There are two connectors, one for the heated grips and one for the 12V accessory socket - this is the one to use for these lights.
I connected to the accessory connector by using pins and grommets from my Sodial kit. The alternative would be to cut off the connector and use your own.
I mounted the lights in the air duct using double sided tape, ran the wiring into bullet connectors each side (so panels can be removed) before continuing to the accessory connector. Checked all was working and then re-assembled everything.
Main and Cree lights
Running lights only
I hope teh above may be of use to others!
Online Nelix
Reply #2 on: 19 May 20, 04:50:27
I used those accessory connectors for my USB port, you can eaily access them by taking off the LHS fairings.
Online boldie
  • Bike: Ninja 1000SX
  • City / Town: Spalding
  • Country: GB
Reply #3 on: 19 May 20, 05:41:19
I do like where you've positioned the DRL's  :062:
Reply #4 on: 19 May 20, 10:14:42
*Originally Posted by Nelix [+]
Useful to know.  :028:
Offline hawkr
  • Bike: z1000sx 2017
  • City / Town: Riga
  • Country: Latvia
Reply #5 on: 20 May 20, 11:27:37
Hi guys,
Is it possible to use DRL's on Ninja 2020 with main lights off?
Because I wanted to do this on my 2017, but apparently running lights come on, when you turn the ignition, but when bike is running, there is no option to turn main lights off, right?
Online mdr1970
Reply #6 on: 20 May 20, 11:55:03
EU regulations state motorcycles must have the light on, so you'd have to manually find a way around this  :006:
Reply #7 on: 20 May 20, 06:49:04
Hmmm why would you want to turn your lights off to make yourself less visible and then fit more lights to presumably make yourself more visible I detect a flawed logic  :027:
Online NoddyNinja
  • Bike: Aprilia Tuono V4
  • City / Town: Rossendale
Reply #8 on: 20 May 20, 08:34:56
*Originally Posted by Teaboy [+]
Hmmm why would you want to turn your lights off to make yourself less visible Andre then fit more lights to presumably make yourself more visible I detect a flawed logic  :027:
 :431:  :461:
Enjoying the V4 "ROAR"
Reply #9 on: 20 May 20, 11:41:47
*Originally Posted by NoddyNinja [+]
:431:  :461:
+1 !
