Author Topic: Z1000SX - 2017 Code 27 ABS issue after tire swap  (Read 139 times)
Offline Hawaii
  • Country: Sweden
So i run a tire shop in my garage.
I changed front and rear tire on a 2017 Z1000SX.
By mistake i mounted front wheel with the ABS disk on the wrong side.
Customer drove home and came back saying the ABS indicator is showing.
I turned the wheel around and the disk is now in the correct position. Nothing was damaged and everything is OK mechanically.
I retrieved the error code and it shows 27 - Front ABS sensor malfunctioning.
I tried tor drive it for 3km stopping and taken out key. Driving 3km more same thing. I also drove 20km took out key and 20km more and took out key.
I also disconnected battery.
Still have an error.
I assume I have to reset the error code some how.
Also if anyone know how to change from mph to Km (I don't have a manual)
Anyone have an idea?
Offline Hawaii
  • Country: Sweden
Re: Z1000SX - 2017 Code 27 ABS issue after tire swap
Reply #1 on: 18 May 20, 12:13:06
Problem solved
Uppdate.
    Drove 5km stop, remove key
    Drove 3km stop, remove key
    Drove 20km stop, remove key
    Drove 20km stop, remove key. + break on gravel. ABS works(probably did the whole time)
    Error lights gone
