burty
Author Topic: Sat Nav power outlet Ninja 1000SX 2020  (Read 7290 times)
#20
Offline TheStig
Re: Sat Nav power outlet Ninja 1000SX 2020
Reply #20 on: 16 Sep 20, 03:16:36
So Mr beads , is the above the right place to look for the cables ?
cheers
Steve
#21
Offline Lodge
  • City / Town: Carlisle
Reply #21 on: 19 Sep 20, 10:56:56
Sorry to jump in but having just done this it may help others to know you can buy a pack of pins here 99p posted which is all you need to use the factory plugs.
https://www.ebay.co.uk/itm/251994363428
Bare in mind the factory plugs are taped to the loom which can make them a little harder to locate. Be sure not to use the heated grip socket for your accessory socket as the fuse rating is higher, if your fitting a wired in satnav as well as power socket you can piggy back off the back of your power socket to supply satnav. I’m a bit OCD but would hate to buy a used bike to find that the factory plugs had been cut off but that’s just me.😎
#22
Offline henkgib
  • Country: sweden
Reply #22 on: 08 Nov 20, 08:52:06
thestig,
 Did you ever find out if it was the connector for the power outlet? I see your picture and almost sure that you are right.... I did install it already but i didn't try it yet.... I'm installing the grip heater now but I'm having a hard time... I think i need to take off the meter cover.
#23
Offline krm76
  • Country: España
Reply #23 on: 05 Jan 21, 05:14:49
Hello there,
After searching and asking what sort of connector does the N1K from 2020 have, I can sy that it is a 2 pin HM 090 connector, not 100% sure though. I've ordered a couple connectors to see if are the proper ones, if so I'll let it know in here.
