Author Topic: FAIRING REMOVAL 2020  (Read 480 times)
0 Members and 2 Guests are viewing this topic.
Online keithzx
on: 26 Mar 20, 03:48:50
hi does anyone know if the removal of the fairing panels on the new 2020 model is the same as the removal from the previous model , thanks  looks the same but may have hidden fasteners ????
Offline kernowjim1
  • Bike: 2018 Z1000SX
  • City / Town: Torpoint
Re: FAIRING REMOVAL 2020
Reply #1 on: 26 Mar 20, 11:03:15
Only one way to find out....get stripping!
Reply #2 on: 27 Mar 20, 06:12:09
*Originally Posted by kernowjim1 [+]
Exactly  :461:
I broke mine putting them back on, not taking them off :oh_no: I was p*ssed, but it's not the end of the world if they do break  :006:
If you find something new, post it for the next guy...or gal  :038:
Online keithzx
Reply #3 on: 27 Mar 20, 06:54:49
Hi if you have already removed them. How did you do it  is it the same as the video on you tube  find when putting them back best to spray done mr sheen furniture wax on the rubber grommets do the pins slide in easier   How did you them cheers
Offline cyanide sid
Reply #4 on: 27 Mar 20, 03:45:08
I always smear a bit of grease onto the grommets and pins to help any future removal .
Also found a couple of the button fixings  were a bugger to push the centre pins in so
found an old Bradawl and ground the point down to about a 3-4 mm flat [ works a treat ]
Offline ian
  • Country: great britain
Reply #5 on: 28 Mar 20, 01:55:17
i have done it i did it when it was just a few days old to put a rad guard etc on
being used to Kawasaki fairings i just proceeded very slowly gave myself all day and it took all day, i didn't know there was a video and i didn't know it was like the 2019 model but i didn't break anything, undid some fasteners i didn't need to, ended up with the screen off as well but better to unfasten them than pull and pull to release something to find some hidden push pin holding it all together and it snaps  :005: :087:
found it a lot simpler than i had imagined compared to the ZZR fairing, put it back using spay polish over the tabs ends/gromets
i just started with the black surround and slowly looked all over the bike gently pulling and using trim tools for vehicle trim to gauge the flexibility and stiffness of the parts
putting it back was ok as the main fairing hooks on the frame meaning everything lines up there or there about
two block fastener to remember one either side of the fairing on the LHS
Last Edit: 28 Mar 20, 02:01:17 by ian
Online keithzx
Reply #6 on: 28 Mar 20, 03:02:30
So do you reckon it is the same as the earlier model to remove and put back on. I managed it ok on my last sx. I fit a rad guard to my last sx and didn’t need to remove the fairings
Offline ian
Reply #7 on: 28 Mar 20, 03:32:42
i used to have a 2013/2014 model before i had the zzr and the fairing removal was simpler than 2013/2014 model particularly the bit where the main fairings fasten to the upper headlight cowl
on the 2013 model i snapped those little hooks
the good thing to me was the fact you can hang the fairing on the frame to assist - that is what i found
on reflection i probably could have put the rad guard on without taking the fairing off as all i did was fasten the bottom of it with the existing nut and bolt and then zip tied the upper to the frame
Online keithzx
Reply #8 on: 28 Mar 20, 04:37:34
so do you reckon that the removal of the 2020 fairings is the same fixings ect as the previous model ?? thanks
Offline ian
Reply #9 on: 28 Mar 20, 05:08:19
i've just looked at the Jonathan Long video on the 2018 fairing removal and that is the same as the 2020 model as i did it, i just removed a bit more as i'd not seen it
