Author Topic: Abs pipe joint nut size  (Read 958 times)
Offline voyager
  • City / Town: Bath
on: 19 Jan 20, 02:26:43
Hello
Due to incompetence I need to replace the metal pipe that leads from the rear brake master cylinder to the ABS Unit.
I know the fitting on the M/C is a std 14mm bolt.
Please can someone tell me joint nut size on the ABS end so I can buy the correct flare  wrench ?
Thanks!
You're not seriously gonna believe this man, are you? ARE YOU? HE ISN'T EVEN FROM 'ROUND HERE!
Offline nimmz
  • Bike: Z1000sx orange
  • City / Town: Devon
Re: Abs pipe joint nut size
Reply #1 on: 19 Jan 20, 03:21:49
10 mm
Offline voyager
  • City / Town: Bath
Reply #2 on: 19 Jan 20, 05:26:10
Thank you!
Have you done this job on a Z1000sx, do you have any tips so it's right first time?
Offline nimmz
Reply #3 on: 19 Jan 20, 08:22:52
*Originally Posted by voyager [+]
Thank you!
I have braided lines but still retains the metal pipe as there is a join part way along.
Offline voyager
  • City / Town: Bath
Reply #4 on: 19 Jan 20, 08:31:45
I've split the metal pipe at the master cylinder end and have ordered the replacement line (£158!😥).
I was concerned about bleeding the ABS pump, the line rear brake m/c and caliper.
How do I get the air out as its "uphill" from the rear m/c to the abs pump?
Cheers
Offline nimmz
Reply #5 on: 20 Jan 20, 09:35:09
It’s a rubber hose at the master cylinder,if that’s what’s damaged you could of got away with a braided hose. Anyway just bleed the system in the normal way, don’t try any reverse bleed it the abs pump won’t like it.
Offline voyager
  • City / Town: Bath
Reply #6 on: 20 Jan 20, 10:57:46
It's the metal hose that goes to the abs box.
Still just bleed in the normal way?
Offline ian
  • Country: great britain
Reply #7 on: 21 Jan 20, 04:22:11
i use one of these for bleeding you don't need to but i find it easier
Mityvac Brake Bleed Kit
also, i though it was an urban myth but, tie the brake lever with a zip tie over night and, it gets the air to the top and out of the system
i did on mine and the brakes were spot on no sponge feel
Offline voyager
  • City / Town: Bath
Reply #8 on: 22 Jan 20, 08:33:38
Misunderstanding on my part and I see how the fluid flows.
Thank you for your help
