Author Topic: Woolich ECU Remapping  (Read 592 times)
Offline Murphyau
  • Bike: 2019 N1K
  • City / Town: Sydney
  • Country: Australia
on: 05 Dec 19, 12:05:40
I would like to change the exhaust system on my 2019 SX early next year, so I have been doing some preliminary research on the matter.
Over Ivan's Performance website, he mentions the following areas/items of improvement with a 1000SX ECU remap. :--
Low gear power limiters removed, Disable speed limiter, Disable fuel cut, Re-program sub-throttles for max power, Change cooling fan's parameters, Reduced engine braking on deceleration, Disable Exhaust Servo error code, Complete re-curve of ignition timing, Raise rev-limit to 11,500 rpm, Disable O2 sensor function and sensor code.
Unfortunately, it seems he does not support the 2017~2019 models, which leaves me with using a Woolich Racing remap instead.
Does anyone know what areas/items are involved with this Woolich remap ??
Offline Runich
Re: Woolich ECU Remapping
Reply #1 on: 05 Dec 19, 11:07:05
I have a 2015 model with a Woolich map that was done by a UK based company, and it covered the items you mentioned: fan, sas, rev limiter etc.  There's a feature list on the Woolich site for your model:
http://www.woolichracing.co.uk/products/kawasaki/z1000sx-ninja-1000/2019/826/2017-2018-kawasaki-ninja-1000-z1000sx-usb-denso-v3-package.aspx
Last Edit: 05 Dec 19, 11:09:01 by Runich
Offline Murphyau
  • Bike: 2019 N1K
Reply #2 on: 05 Dec 19, 06:52:53
Excellent.  Many thanks.   :828:
