Author Topic: Sargent seat & Kawasaki seat cowl  (Read 1059 times)
Offline ZPETE
on: 08 Oct 19, 01:36:04
I have just purchased a seat cowl for my 2015. It doesn't fit with my Sargent seat....Doh!  :oh_no:
I love the look of the cowl and love the comfort of the Sargent seat.
Has anyone else had this issue? Is there a solution?
The only way I can see is to trim the seat cowl which I am reluctant to try.
Any tips would be great or otherwise I will re-list the cowl on here if anyone interested?
It is Candy Lime Green, 2014-16.
Cheers, Pete.
Offline Winch Rob
  • Bike: 2014 Sx,1999 R6
  • City / Town: Winchester
Re: Sargent seat & Kawasaki seat cowl
Reply #1 on: 08 Oct 19, 07:34:24
I have a similar problem as my seat was done by Tony Archer and the seat cowl front edge digs into the seat making it hard to latch.So I put some packers under the latch plate on the seat cowl effectively extend the latch and making easier to lactch with digging inti the seat.There is bit more of a gap around the seat cowl but still looks fine.
2014 sx candy lime green,givi screen,scotoiler,Beowulf rad guard,
Seat cowl.
Offline ZPETE
Reply #2 on: 08 Oct 19, 07:44:39
Thanks, i will look at trying that tomorrow :031:
Offline NoddyNinja
  • Bike: Aprilia Tuono V4
  • City / Town: Rossendale
Reply #3 on: 08 Oct 19, 08:32:05
*Originally Posted by Winch Rob [+]
+1 on 2014 with Sargent seat
Enjoying the V4 "ROAR"
Offline Jimbrodie1
  • Bike: 2017 Z1000SX ABS
  • City / Town: Nantwich
Reply #4 on: 09 Oct 19, 12:10:26
Same solution here. Couple of washers between the latch and the cowl will raise it up, but I also got a short length of breather hose and slit it along it's length then put it on the front lip of the cowl that rests on the back of the seat. This stops the cowl wearing and cutting in to the seat.
I did put some pictures on here a while ago. If you do a search for Sargent Seat you may find them  :028:
Offline ZPETE
Reply #5 on: 09 Oct 19, 08:19:38
Great advice guys :828: and Im going to try it out tomorrow.
To avoid too much trial and error, approx what thickness spacer should I try? And should I put similar spacer under the rear mount of the latch plate?
Offline Winch Rob
Reply #6 on: 09 Oct 19, 08:55:59
I used 2mm to start with see what you think but you can’t use much more as you will loose thread engagement on one side of the latch as both bolts are the same length,you will see what I mean when you look tomorrow.The rear mount isn’t necessary to pack out as it still slips into it’s location ok.
Seat cowl.
Offline ZPETE
Reply #7 on: 09 Oct 19, 09:02:13
Thanks Rob, I will let you know how i get on.
Offline ZPETE
Reply #8 on: 12 Oct 19, 09:24:15
I finally got round to doing the spacers and yes it works a treat....I will have to decide if I can live with the slightly imperfect alignment cos Im a fussy git like that!
Thanks for the advice chaps :031:
