Author Topic: Very strange occurrence, may be some one can help, please  (Read 1218 times)
Offline shigidar
  • Bike: Z1000SX 2016
  • Country: Israel
Hello all, i have 2016 model
Every Saturday we go to a "spirited" canyon ride, most of the time the bike around 7000-9500 rpm all gears, today on several occasions ( 3-5 times) during the ride while with open throttle during acceleration i had some little "kick" like the bike went in to gear. Very subtle but noticeable, of course i thought may be the chain skipping a tooth or something and checked that, it seems to be OK.
It was really strange, and the best description i can give like it was in gear and running and accelerating but only 98% in gear and then it was 100% in gear.
Any thoughts will be appreciated as i need to check it with the garage and want to know possible causes.
Thank you all
Are you 100% happy with your gear lever position  :027:
This bike does require this and a good papyrus shift for accurate engagement  :028:
Offline BikerJoe
  • Bike: '14 Z1000SX
  • City / Town: Stockport
Riding like that with full throttle and high revs, I'd suspect it's the traction control kicking in and reducing the power momentarily as the rear wheel skips over road bumps or loses traction on patches of dirt or bits of gravel.
Offline DavidStonework
  • Bike: z1000SX 2017
...or a very mucky chain and front sprocket maybe? Build up of grease and general crap can cause occasional skipping.
Offline shigidar
  • Country: Israel
*Originally Posted by DavidStonework [+]
It is not the traction control, When the traction control is active there is a indicator on the dash.
Online burty
Its most likely the bike not going into gear properly.  These gearboxes are sensitive to a positive gear change.  Check and adjust the lever as mdr1970 said above.
Offline nimmz
  • Bike: Z1000sx orange
  • City / Town: Devon
*Originally Posted by burty [+]
:461: mine did it on Saturday when I did a “lazy” gear change rather than the usual positive one.
Offline shigidar
  • Country: Israel
*Originally Posted by nimmz [+]
if it were lazy gear change gear how does the bike was still accelerated after the gear change and before i felt the little "knak" ?
Online burty
*Originally Posted by shigidar [+]
It's because it's only partiality engaged.  I have experienced the same.
Offline shigidar
  • Country: Israel
