Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Finding Neutral  (Read 520 times)
Offline Harrycaine
  • Bike: 2018 Z1000SX
  • City / Town: Sussex
Finding Neutral
« on: July 11, 2019, 07:17:20 PM »
Finding Neutral seem to be a challenge when the bike is hot. Often get "-- " in the display , not a really big deal but a little irritating. Anyone else see this (2018, 2800 miles)
HC
Offline tonyt4
Re: Finding Neutral
« Reply #1 on: July 11, 2019, 07:55:21 PM »
Works fine for me, 2019 model 6,000 miles, but
being a bit useless if I come to a stop and I am still in third, it is really hard to get it down, and then into neutral.  Then I lose the gear reading.
Even worse from fourth   :008:
Tony
Online KD
Re: Finding Neutral
« Reply #2 on: July 11, 2019, 08:18:47 PM »
Adjust your gear lever so its right for your boot at rest and make sure the chain is tensioned correctly.
Offline Mr NSB
  • Bike: Z1000SX WJF
  • City / Town: Andover
Re: Finding Neutral
« Reply #3 on: July 11, 2019, 11:13:20 PM »
Kawasaki’s have a neutral finder. If you are stopped and in first gear just click up and it should only go into neutral, it won’t go into second unless the bike is moving.
Re: Finding Neutral
« Reply #4 on: July 12, 2019, 12:14:40 AM »
Same problems on mine finding neutral is erratic at times mostly when hot. Chain and lever set properly. Really annoying
Offline Sojourner
  • Bike: '14 Z1000SX
  • Country: Thailand
Re: Finding Neutral
« Reply #5 on: July 12, 2019, 01:36:56 AM »
I'm normally in 1st by the time the bike comes to a stop but sometimes I forget. If it doesn't go into neutral or 1st easily while stopped I let the clutch out just a little then pull back and that allows the gears to mesh without a problem.
Offline kernowjim1
  • City / Town: Torpoint
Re: Finding Neutral
« Reply #6 on: July 12, 2019, 09:46:59 AM »
An oil change often cures this problem
Re: Finding Neutral
« Reply #7 on: July 12, 2019, 10:08:40 AM »
Personally think it's fairly normal on most bikes and don't consider it a problem myself  :019:
As KD states, having your lever correctly positioned helps, but being gentle when looking for neutral and also sometimes if it doesn't engage first time, I'll rock the bike back/forth a tad and it'll drop in in my experience  :028:
Offline Harrycaine
Re: Finding Neutral
« Reply #8 on: July 12, 2019, 08:10:00 PM »
Sounds like most of us have the same issue. This one is worse than most other bikes I've ever had, but you're right most do it to a degree.
Good tip on the neutral finder, thanks for that one.
I do find that when I get the "--"  if I carefully let out the clutch it's often in neutral anyway and once the clutch is out "N" magically appears.
HC
Offline Tusker
  • Bike: 2019 Z1000SX
  • City / Town: Wigan
Re: Finding Neutral
« Reply #9 on: July 13, 2019, 10:25:29 AM »
just to put it in to context, I'm 2400 miles on a 2019 Z1000SX and have had no problems at all. But the Tiger 1050 I traded in was a nightmare.. Funnily all advice was same, good lever adjustment, good chain tension and good oil.....
