Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: oxford heated grips  (Read 415 times)
Offline alanb2019
  • Bike: kawasaki z1000sx
  • City / Town: tyne & wear
oxford heated grips
« on: April 15, 2019, 10:38:21 AM »
there seems to be a a high edge at the end of the right hand bar , does the new oxford grip go over this or does it need grinding off
Re: oxford heated grips
« Reply #1 on: April 15, 2019, 11:25:29 AM »
You need to sand it down gently. I have a thread somewhere with pics let me see if I can find it.
« Reply #2 on: April 15, 2019, 11:32:13 AM »
https://www.z1000sx.co.uk/index.php/topic,10502.msg120906.html#msg120906
There ya go. Have a look through, there is also a link to another thread on it inside.
Offline alanb2019
« Reply #3 on: April 15, 2019, 01:12:02 PM »
thanks that helps a lot  :828:
Offline cyanide sid
« Reply #4 on: April 15, 2019, 06:04:05 PM »
Yes you will have to remove that high edge on the right hand bar ,I found the easy way was to
trim it off with a stanley / craft knife and then sand the high bits down. On mine there was also
some what I can only describe as raised vein's that may or not need to be removed .
There was also on mine an inner high edge that was exposed after removing the old grip and you can either remove that one as well or simply butt your new grip up to it in which case you will have to
trim some off the length of the new grip
