Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Shad Top Box  (Read 1892 times)
Offline CraigZ
  • Too old for a mid-life crisis
  • Bike: 2017 Z1000SX
  • City / Town: Kent
Re: Shad Top Box
« Reply #20 on: May 03, 2019, 07:30:38 PM »
Part no. is stated earlier in this thread.
Offline Teaboy
  • Bike: 18 Fusion Silver
  • City / Town: Nth Lincolnshire
Re: Shad Top Box
« Reply #21 on: May 04, 2019, 06:09:38 AM »
Offline robertsurrell
Re: Shad Top Box
« Reply #22 on: May 05, 2019, 11:20:28 AM »
Cheers
Robert
Offline Raj
  • Simple rule,never give up!
  • Bike: Z800abs,Z1000SX
  • City / Town: Surrey
Re: Shad Top Box
« Reply #23 on: May 05, 2019, 01:22:59 PM »
I fitted a evotech performance tail tidy & shad top box rack on my 2019 SX so I can fit a givi monolock Base plate to use my existing Givi V47 top box. Result,no issues apart from drilling out the security bolt to drop the tail. 😎
Offline Teaboy
Re: Shad Top Box
« Reply #24 on: May 05, 2019, 04:22:45 PM »
No need to drill security bolt simply use a large flat bladed screwdriver with a good square edged tip, plenty of down pressure abd screwdriver will bite in to the soft bolt head and unscrew it no problem its not in that tight. Replace with a standard bolt on reassembly
Offline Raj
Re: Shad Top Box
« Reply #25 on: May 05, 2019, 04:59:31 PM »
If you are able to get bolt off without drilling, super. Mine was thread locked as well. Probably get a dealer to remove it for you before you drop the tray. I don't think anyone on this forum fitted the comb I fitted , not that I could find. Evotech performance tail tidy/shad top box rack/givi monolock Base plate. Good lock.
Offline Teaboy
Re: Shad Top Box
« Reply #26 on: May 05, 2019, 05:25:23 PM »
Security bolt is thread locked but it is soft compound and doesn't set solid so easier to undo
