Author Topic: Brake fluid flush  (Read 1139 times)
Offline Idwal67
Brake fluid flush
on: 05 Mar 19, 07:10:08
Thinking of using this too flush through/replace old brake fluid
Is this overkill or good value
Motul RBF660 100% Synthetic Race/Racing/Rally DOT 4 Brake Fluid - 500ml
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F301149062246
What do u think/recommended
Cheers
Re: Brake fluid flush
Reply #1 on: 06 Mar 19, 10:02:03
No idea really. However, unless you are hard on your brakes or do lots of track days I'd probably stick to regular DOT4.
Offline Idwal67
Reply #2 on: 06 Mar 19, 04:44:39
Cheers
Reply #3 on: 06 Mar 19, 06:04:28
I've not used racing dot 4 but have swapped out standard dot 4 for dot 5.1 (DO NOT MIX UP WITH DOT 5 THIS IS NOT COMPATIBLE!!!)
Dot 5.1 has different properties to dot 4
http://www.bigrideracing.co.uk/2016/01/07/dot-4-or-dot-5-1-whats-the-difference-and-which-do-i-need/
May be a useful read.
Last Edit: 06 Mar 19, 06:06:52 by Scotty001
