Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Fuel tank off! Now bike won't start...  (Read 666 times)
Offline Boogie_boy
« on: January 21, 2019, 10:30:42 PM »
I took the time to fit a Scott oiler the proper way, so I've had the tank off, I've now re-fitted everything, now the bike will turn over but won't start. I've checked for trapped wires pipes etc beneath tank and all seems good. Anyone experienced this before?
Re: Fuel tank off! Now bike won't start...
« Reply #1 on: January 21, 2019, 11:21:32 PM »
Does the fuel pump prime when you first turn the key?
Offline kellyboy
  • Bike: 2014 Z1000sx abs
  • City / Town: Lincolnshire
« Reply #2 on: January 22, 2019, 03:39:02 PM »
Did the same thing yesterday with my Dl1000. Found that I'd failed to connect the connector underneath the tank at the same time as I connected the hoses. Fortunately it was visible without removing the tank so I simply reconnected it and it struck up first turn-Result.
Offline Boogie_boy
« Reply #3 on: January 22, 2019, 08:49:51 PM »
*Originally Posted by Ninjamaster [+]
Yes it does.
« Reply #4 on: January 22, 2019, 10:05:25 PM »
Worth checking the fuel hose is fully pressed home over the nozzle on the end of the pump. If i remember rightly it can feel like its pushed on but then needs another 5 or 10mm of movement to be fully seated before you put the red plastic clip down to lock it in place.
Offline Boogie_boy
« Reply #5 on: January 23, 2019, 12:48:30 PM »
Foxy, yeah I made the mistake, fuel came out, its fully home now. May just require turning over more  once battery is connected to power pack.
« Reply #6 on: January 23, 2019, 03:10:08 PM »
*Originally Posted by Boogie_boy [+]
Good shout from Foxy.
Make sure the red lock clip is visible when looking from the metal tube side. This proves the flexible pipe is properly pushed home.
Offline Boogie_boy
« Reply #7 on: January 23, 2019, 08:00:41 PM »
Nope, tube is all the way in and clip fully home. When I said turning over I meant the engine not the pipe.  :001:
Offline Boogie_boy
« Reply #8 on: January 25, 2019, 07:44:01 PM »
(SOLVED)
One of the 2 electrical connections on the front of the air box wasn't fully home,  :430:
« Reply #9 on: January 25, 2019, 08:24:12 PM »
(SOLVED)
 :028:
