Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Replacement chain and sprocket set  (Read 1179 times)
« on: November 25, 2018, 03:59:15 PM »
I started the preparation for the installation of a new chain and sprocket set. This is inside the engine sprocket cover after 2.5 years 15.5K.
And this is it after cleaning
I've bought a impact wrench that I'm hoping will do the job of removing the sprocket nut, it's over spec at 480Nm - the nut is torqued to 147Nm.
I've got the sprocket nut soaked in WD40 and will leave it for 24/48 hours
Re: Replacement chain and sprocket set
« Reply #1 on: November 25, 2018, 04:43:53 PM »
Subscribed for updates.
Most interested in hearing how you get the front sprocket nut off. Keen to have a go at this when my time comes. The front sprocket being the only thing that concerns me a bit!
Offline Fair Weather
  • Bike: Z1000sx
  • City / Town: Tenbury Wells
« Reply #2 on: November 25, 2018, 06:44:56 PM »
I normally get someone to sit on the bike and hold the back brake on, before you take the chain off, of course.
The nut usually come off quite easily. :046:
If it looks to good to be true, buy it.
Offline Dailyrider
  • YOLO.
  • Bike: 2014 Z1000SX
« Reply #3 on: November 26, 2018, 06:41:35 AM »
I needed my chainset replacing just recently but bottled it entirely (as I weighed up the cost of the gear I'd need and heard horror  :005: stories about the front sprocket nut) so I got the guys at Corby to do it when they serviced the bike. It is now running like new - a mahooosive difference.
Good luck :028: and post the photos plz (v. interested if the stories are true).
Miles = Smiles
« Reply #4 on: December 01, 2018, 11:42:08 AM »
I finally got around to removing the front sprocket this morning - SUCCESS!  :celebrate:
With the bike on the side stand, front brake tied on, rear brake weighted on (small sledgehammer) and front and rear wheels chocked I held my breath and brrrrr, brrrr (thought I saw signs of movement), brrrr off it came!
This is the impact wrench that I used.
 https://www.ffx.co.uk/tools/product/Draper-Iw1000Sf-5010559829941-1-2In-Impact-Wrench-Kit-230V
It's a bit more expensive than a couple of others, but it's a solid piece of kit and comes with four separate sockets (rather than two combined sockets) and a 6m mains lead which is great. I had to buy a 27mm impact socket though.
Very happy.
« Reply #5 on: December 01, 2018, 01:02:53 PM »
*Originally Posted by whyhaveone [+]
Very happy.
Nicely done mate.
« Reply #6 on: December 03, 2018, 04:38:13 PM »
All fitted today, went really well. I've just got to adjust the chain tension, torque everything up, put the engine case and fairing on and give her a clean.
One good thing about doing this yourself is you can give everything a good clean whilst the bike is exposed, including the rear wheel whilst removed.
Front sprockets - slight hooking to old sprocket.
https://photos.z1000sx.co.uk/image/wRW9h
Rear sprockets, very little visible wear to old sprocket
https://photos.z1000sx.co.uk/image/wRSQB
Front sprocket holder before cleaning. Not so bad.
https://images.z1000sx.co.uk/front-sprocket-inner.md.jpg
Dirty inside swingarm
https://images.z1000sx.co.uk/inside.jpg
« Reply #7 on: December 03, 2018, 05:15:57 PM »
Wow that is one worn front sprocket compared to the new one!
« Reply #8 on: December 03, 2018, 08:22:52 PM »
*Originally Posted by Ninjamaster [+]
I think that's pretty normal wear for a chain and sprocket set that's due replacement. I've seen very much worse.  Remember that the front sprocket wears 3 times faster than the rear.  Which is why I don't mind fitting a relatively fast wearing alloy rear sprocket.
2011 Z1000SX, in GREEN, owned since September 2011.  50,000 miles, MCT tweaked front suspension, Maxton Rear shock, heated grips, MRA dark sport screen, PDoiler, Scorpion Serket Exhausts.
« Reply #9 on: December 03, 2018, 08:48:02 PM »
Kool didn't know that!
