Did you miss your activation email?
Members have access to more features - join up today !
Please
login
or
register
Home
Forum
FAQ's
Search
Members Map
Photos Gallery
Login
Register
22 Feb 19, 05:49 AM
Kawasaki Z1000SX Forum
Z1000SX Chat
Maintenance, Servicing, and Mechanical
X or V system single or dual injector?
What did you do to your Z1000SX today?
Where did you go on your Z1000SX today?
Exhaust gallery thread
LED Headlight Bulbs
Service Costs
Dates for April 2016 Spring meet
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: X or V system single or dual injector? (Read 1599 times)
Ninjamaster
SX God
Topic Author
What's a corner?
Bike: 2018 z1000sx
City / Town: Essex
Country: United Kingdom
Re: X or V system single or dual injector?
Reply #10 on:
October 11, 2018, 07:55:10 PM »
True
As I said in an earlier post I wish I had listened to the guys here and gone with the pd oiler it's cheaper by good margin. The x system is good but over priced for what it is.
It takes some getting used to though as I ve had it a couple of months and still can't decide if I have enough oil on the chain or not. I'm. So used to caking on spray lube. I guess time will tell in terms of chain wear and adjustment etc.
What I will say though is if. You haven't trjed an oiler buy one. I commute daily and it's made my. Life soo much easier.
Logged
Rocky the Dog
SX God
Bike: XR34 and TZ350
City / Town: Newent & Marlow
Country: UK
Reply #11 on:
October 12, 2018, 11:00:55 AM »
Have used scottoiler v systems on my last 5 or 6 bike over a 10 year period. All with a lube tube added which increased the range to 3-4k before refills. Once set up they have all worked flawlessly and increased chain life massively. Its probably the best investment you can make on a chain drive bike. Never used anything other than the single sided feeder. you can add the twin but I'm not sure what extra it brings.
Rgds Steve
Logged
Only a Biker understands why a dog puts its head out of car windows
Scotty001
SX Master
Bike: 17 Z1000sx
City / Town: Hampshire
Country: UK
Reply #12 on:
October 12, 2018, 11:57:36 AM »
Originally Posted by
Rocky the Dog
Rgds Steve
The twin gets both sides, if you looked at the side of the chain closest to the wheel it would have looked in a rougher state and not as well lubricated. Scottoiler were the go to system for automatic chain oiling and I too used them for over a decade, but there are now many more out there to choose from which are just as good if not better when cost factor is brought into it. I now use a Pd oiler which as standard needs to be re fuelled every 3k miles (no extea lube tube needed) . It's so much cheaper to buy than a Scottoiler and simpler to install. I have however paired it with the Scottoiler dual injector so both sides get equally lubed.
Logged
Ninjamaster
SX God
Topic Author
What's a corner?
Bike: 2018 z1000sx
City / Town: Essex
Reply #13 on:
October 12, 2018, 05:20:25 PM »
I adapted a dual injectoe too for the SX. Only requires a few extra washers. Find it lubes both sides OK but I want to find a. Way of keeping my. Paddockstand bobbins so I can quickly. Lift the bike. Instead of using the Anna stand.
Logged
Rocky the Dog
SX God
Country: UK
Reply #14 on:
October 12, 2018, 10:44:57 PM »
Scotty001
Scotty, if you have the setting correct and the nozzle in the correct position, the oil spreads well enough across the entire chain. Never had any issues and at one point about 8 years ago I was riding about 20k a year in all weather's - though I will admit my Scottoiler was always set on the generous side. Never an issue. Plus as to price, I bought all mine in ebay auctions and never paid more than £45 for one. And they were all boxed and new. You just need to keep an eye out for bargains as there are plenty to be had though the last one I bought was about 6 years ago and I had used it on my previous Honda before the sx
Last Edit: October 12, 2018, 10:51:17 PM by Rocky the Dog
Logged
ellewasal
SX Junior
Country: UK
Reply #15 on:
October 15, 2018, 12:28:58 PM »
scottoiler want over £50 for a spare v system dispenser. Buying at auction defeats the idea that the oiler is operational continuously when the bike is running and also its a whole new kit when all that is required is a stronger spring, thus wasting resources and putting more rubbish plastic into the environment
Logged
Ninjamaster
SX God
Topic Author
What's a corner?
Bike: 2018 z1000sx
City / Town: Essex
Reply #16 on:
December 03, 2018, 09:20:27 PM »
So guys I've had the xsystem for sometime now, it's does what it says on the tin and I love the convenience but I'm finding spots of rust on my putter link plates..??
I clean weekly with kerosene let it dry off and then paint a thin layer of scottoil on inner and outer links as well as across middle of chain.
Others having this problem? Only done 1900miles, worried about chain longevity if its this prone to rusting.. My ninja 650 chain links siezed in 4k with meticulous maintenence even the tech commented when the chain was changed under warranty that it was clean and well looked after.
Both bike chain had DID marked on the side so they should be quality chains!
Logged
burty
SX God
City / Town: Rochester, Kent
Country: UK
Reply #17 on:
December 04, 2018, 06:32:24 AM »
Ninjamaster
The oem chains are uncoated steel so will rust, particularly if you clean it off regularly. Personally I wouldn't clean it. If you have the scottoiler set correctly it's self cleaning, that is one of the benefits of a chain oiler. In my experience cleaning a chain often does more harm than good and is not worth the effort unless the chain is particularly gunked up, which doesn't normally happen with an oiler.
Last Edit: December 04, 2018, 06:37:55 AM by burty
Logged
2011 Z1000SX, in GREEN, owned since September 2011. 50,000 miles, MCT tweaked front suspension, Maxton Rear shock, heated grips, MRA dark sport screen, PDoiler, Scorpion Serket Exhausts.
Ninjamaster
SX God
Topic Author
What's a corner?
Bike: 2018 z1000sx
City / Town: Essex
Reply #18 on:
December 04, 2018, 06:47:46 AM »
Thanks for the info burty will clean off rust and reduce the cleaning schedule and see if that keeps the rust away.
Logged
Print
Pages:
1
2
Go Up
« previous
next »
Z1000SX Chat
Seat Bag
Accessories and Products
Teaboy
Yesterday
at 09:46:14 PM
Exhaust
Dicky-Art
Yesterday
at 09:14:30 PM
Black Baglux tank cover + Seat cowl Black off 2013
Parts, Accessories & Clothing For Sale
Tobyjames
Yesterday
at 08:11:21 PM
Z1000SX Seat cowel Metallic Spark Black
Ninjamaster
Yesterday
at 06:00:22 PM
Riding in France
Touring Chat and Ride Reports
Dominic-h
Yesterday
at 05:29:11 PM
Z1000SX - General Discussion
unclefester
Yesterday
at 05:28:16 PM
London Motorcycle Show
unclefester
Yesterday
at 05:27:12 PM
As new - Top Sellerie heated seat for sale
Dominic-h
Yesterday
at 03:54:20 PM
